Integration help, urgent.
As written, the integral of 2x/x^2+1 is x+ 2log(x) + constant.
The derivative of X^2+1=2x, you probably didn't spot that.
When you see a fraction, look for derivatives as it makes it much easier than substitution.
And good luck, please no annoying vector questions :(.
Thank you all for the quick replies, especially Amleto and RomanNose.
Makes sense now.
Thanks good luck to you as well, I have a feeling it isn't going to go well for me but I've done my best.
This.
Make it the first thing you check in an integral question involving a fraction. I will probably forget to do this in the exam tomorrow.:D
