- 23 Nov 2005
I am not sure if this is the correct forum, but I need some advice about my CPU.
Its a Intel PIV 560 (3.6Ghz), its about 13 months old now and has constantly run at a high temp since I first got it. I used to have the Asus Star Ice cooler but it was too noisy (and so heavy it warped the mobo) so I removed this and replaced it with the Retail cooler (and Artic silver 5). Under stress my temp now reaches 75c which I know is not good, however I have a more worrying problem.
My CPU never goes above 70% - at the moment I am running the torture test on Prime95 (Blend) and my cpu is averaging between 60 and 70%, the CPU temp is peaking around 75c.
it looks like my cpu is throttling itself because of the high temps, is that correct?
I have ordered the freezer 7 pro so hopefully that will help with the temps.
Any response welcomed - except those buy an AMD posts hahaha I will be buying an AMD as soon as they support DDR2 lol spent £140 on my RAM want to make the most of it dammit
**Edit for spelling DOH!**
