Intel 980x
29 Jan 2007
Hi,
I have a Rampage 3 on order with OC which I was planning on putting my 920 into but now debating ordering the 980x and using the 920 to upgrade our other PC.
Just wondering if it's worth the upgrade from the 920 to the 980x, having a look around I've found the 980x is cheaper by about £60 elsewhere which is a shame as I'd rather have ordered it from OC if I was to go ahead with the upgrade.
I use my system solely for gaming, most of which probably would not benefit for the upgrade.
Peeking at the 980x OC thread it would appear they dont clock any higher than a 920/930. So unless you can match your 920 clock, it may well end up slower in games.
