- 28 Jun 2005
I'm looking to replace an ageing unRAID server but struggling to find a motherboard that meets the following criteria:-
My current setup is on it's last legs so want to move all the drives across to a new system so the number of SATA ports is key until I can sort out a decent HBA with cooling. Anyone got any pointers for a budget of £150 - £250? Won't be having a dedicated GPU installed and not fussed about RGB or anything. Only one possibility I've seen is a ASRock Z490 PG Velocita. Thanks.
- Supports Intel 10th Gen with iGPU (likely i3-10105)
- Must have at least 8 SATA ports
