right guys i was testing intel burn test to check if my 4ghz overclock was stable i ran 5 passes at very high NOT maximum cos it came up with a message that i didnt have enough system ram.. i ran 16 threads on intel burn test as i knew 8 threads had a bug in the program... well it ran 5 tests and all were passes but the weird thing is that i had real temp (version 3.00) open and CPU load was not at 100% all the time it fluctuated between 50 and 80% load continusly is this normal??? (intel burn test version 2.3)
if everything is normal and it was supposed to do that im gonna run 20 passes and then im a member of the 4ghz club lol
