Intel Burn Test Problem - Help!
2 Mar 2009
Nottingham
All CPUs I've had in the past I have tested using Intel Burn Test (amongst other things) when stressing. I always use the MAXIMUM Stress Level for 50 runs when testing an overclock.
My previous 3 Intel and AMD processors have always reported back with the expected 'Speed (GFlops)' and always take about 30secs/1 minute per 1 test.
However my latest i3 560 @ 3.8GHz takes 3-4 minutes per test?!?
Does RAM affect this? I was sent Tri-Channel memory instead of Dual-Channel by OcUK - could this be an issue?
The larger the problem, the more memory it uses, the longer it takes. Time per test isn't relevant, Gflops is what matters.
If it randomly takes longer it usually means its not quite stable
like if it take 57 seconds at 4ghz then you clock to 4.1ghz and it take way longer like you say i normally give it a bit more volts and it sorts it out
It gets about 23 GFlops and this takes about 210secs.
My old Athlon II X2 245 @ 3.6GHz got 21 GFlops, and took 70secs.
This isn't once or twice, I have tested LOADS.
Hi, check to see if your memory volts is set to manufactures permited maximum, mine is 1.66v, try putting your CPU core volts up a notch at a time, IBT 20 runs is enough.
What do you get stock compared to clocked
seconds and flops
Good question, don't remember! Will check shortly.
I've now got the memory running at 1520 MHz with 1.58v. This was stable for 25 runs of IBT Max.
Highest GFlops was 25.1 which I reckon is fine (judging by comparisons), but it still takes ~190secs per run.
I guess I was suprised because of the results from my desktop i5 750 too (all tested multiple times):
i5 750 @ 3.8GHz, 4GB DDR3 @ 1520MHz = ~55 GFlops in ~80 secs
i3 560 @ 3.8GHz, 4GB DDR3 @ 1520MHz = ~25 GFlops in ~190 secs
Athlon II X2 @ 3.6GHz, 2GB DDR2 @ 840MHz = ~21 GFlops in ~70 secs
I'm not saying this is wrong, just trying to understand (and check all is well).
Do you think that the i3 takes twice as long as the Athlon due to double memory?
And in turn, the i5 is twice as quick as the i3 because of the 2 extra pyhsical cores?
I should stop thinking about this! Thanks for all of the posts so far though ;)
You should run it with the correct threads set for your cpu not auto and set the ram to the free memory that you have under task manager not avialable ram but free ram.
None of the auto settings are valid.
A very rough analogy for you case. Think of the memory as the distance to travel and the GFlops the max speed you are going.
So in answer to your questions...yes and yes
Tried this, but exactly the same results (score and duration). Set the i3 to AUTO threads and then 4 threads.
I find when I run this I always get different gflps resultsbut I wouldn't worry about it you're only using it to test your overclock.
ps I always assumed that the more ram it used the slower the gflops as it is testing the number to a higher precision but that's just a guess!
