Intel Centrino Advanced N6230 1 antenna or 2?
30 Apr 2007
UK
Hi, I have one of the above adaptos in my new laptop.
I understand they support up to 2 antennas, but I also undertand it is common for manufacturers to only fit one, thus crippling the performance.
How do I tell if my adaptor has one or two antennas installed? I presume its a simple matter of opening up the case and looking, I assume the antennas are small thin wires attached to the card?
I also understand that extra antennas can be bought and installed relatively easily.
From what I've read two antennas on the card will improve performance (all other wifi devices on my network are N rated, Mimo router, etc).
Thanx for any info you can provide...
