- 31 May 2007
HI,
Sounds as if the stock Intel Cooler on my P4 3.6 660 is on its way, fan kicking in often and very noisy when it does. Was looking to replace it with eiher :
http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-ZA&groupid=701&catid=57&subcat=821 - Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler
or
http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR&tool=3 - Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775)
Was wondering which would be best in terms of easy to fit and performance (looking for as little noise as possible)?
Many thanks
or
Many thanks
