Intel Core 2 DUO E6400 "LGA775 Allendale" avaliable?
16 Jul 2006
Birmingham/oxford
Hi im sat here looking at my checkout including an Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail (CP-127-IN)
Unfortunately overclockers shut 20 mins ago just wondering if anybody knows when these are due in, status says pre-order at the moment
Thanks for any help
He wants the retail version, personally I would just get the OEM and buy a good heatsink like the:-
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
Total cost is much the same, and you get a considerably better cooler.
Jokester
As far as I'm aware that HS is significantly better than the stock retail on, so you should be able to squeeze a little bit more out of your CPU. Something like a Scythe Ninja would be even better but it's a bit more expensive.
Jokester
