Intel Core 2 Quad Q6600 and Abit IP35 Pro: Running slow??
Man of Honour
21 Feb 2006
I am not really an overclocker but running CPU-Z today I noticed that my CPU seems to be running very slow. Below is the HTML output from CPU-Z and from what I can tell (and I might be reading it all wrong) it shows my CPU is running at 1632.2mhz not the 2400mhz I had expected to see. I would really appreciate someone having a nose and giving me some advice, ideally what is wrong (if anything) currently and what I should be able to run this spec at with standard cooling.
I have aBit's uGuru installed (not that I can use it well) if this makes life easier and I am upto date with my BIOS. Thanks in advnance for any help offered!
Number of processors 1
Number of cores 4 per processor
Number of threads 4 per processor
Name Intel Core 2 Quad Q6600
Code Name Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Package Socket 775 LGA
Family/Model/Stepping 6.F.B
Extended Family/Model 6.F
Core Stepping G0
Technology 65 nm
Core Speed 1632.2 MHz
Multiplier x Bus speed 6.0 x 272.0 MHz
Rated Bus speed 1088.2 MHz
Stock frequency 2400 MHz
Instruction sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache (per processor) 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache (per processor) 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory Frequency 408.1 MHz (2:3)
CAS# Latency (tCL) 5.0 clocks
RAS# to CAS# (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 18 clocks
Command Rate (CR) 2T
System
System Manufacturer .
System Name .
System S/N System Serial Number
Mainboard Vendor http://www.abit.com.tw/
Mainboard Model IP35 Pro(Intel P35-ICH9R)
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Date 05/26/2008
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
Module 3 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
Module 4 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001)
DirectX Version 10.0
Looks like you have Speedstep enabled in BIOS - The multiplier will ramp up to x9 when the CPU needs it :D
At default your multiplier / fsb should be 9*266 I believe = 2.4ghz
Have you changed anything in your bios?
I have changed everything back to default as I felt that was a good starting point.
I will go an have a nose right now and let you know.
Cheers so far!
Not sure it adds anything, but here are the CPU-Z screens.
I thought I had switched it off in BIOS but I now seems to cycle between 1632mhz and 2440mhz. Does anyone have any pointers how to control this at all and where exactly I need to switch it off or on, or whether I even need to bother?
