Within the past year or so I've noticed the CPU fan acting strangely. When it's idling the fan will go from 10% to 40% rapidly, and back down to around 10% again. I've checked the CPU temp using HWMonitor, and while there is some correlation the fans still get loud even if the CPU usage is very low.
I downloaded this program called FanControl to manually control the fan speed which works well. The CPU package temp can be around 40-50 C and when I disable FanControl the fan speed automatically goes up to what sounds like nearly full speed. Has anyone else had this issue and are there any solutions besides forcing the fan to be consistent while idling using FanControl? The temperatures are low, around 40 C but without FanControl it's like the fan doesn't know what speed it should be and it keeps going up and down. Hours after playing a game the fan speed will seem to stay stuck at whatever it was during the peak of a gaming session (even though the CPU has cooled down) and it'll stay like that indefinitely until I either restart or use FanControl to force it lower.
