Intel CPU Help
Several differences including price.
If you are gaming and have the budget you should be considering i7.
For technical comparison take a look at this page that should display all the variants and their spec. Click here
personally i would just go with an i7 920 d0 stepping. The price between the chips isnt that much tbh. X58 is probably at least a bit more futureproof than the other chipsets too.
