Intel CPU: i3-2100T, LGA1155, 35w
2 Dec 2004
Under The Desk, Wales
Good enough to use with photoshop? I need a fast CPU but also one that is not heavy on the 'w'. 35w seems great as it will be in a small enclosure.
Would a Quad be better? Is there a quad that has a low 'w' output?
sure
http://geizhals.at/580307
Intel Core i5-2500T, 4x 2.30GHz, tray (CM8062301001910) ab €182,90
Quad-Core "Sandy Bridge" • TDP: 45W • Fertigung: 32nm • DMI: 5GT/s • L2-Cache: 4x 256kB • L3-Cache: 6MB shared • Stepping: D2 • IGP: HD Graphics 2000, 650MHz (Turbo: 1250MHz) • Memory Controller: Dual Channel PC3-10667U (DDR3-1333) • SSE4.1, SSE4.2, AVX, Turbo Boost (3.30GHz), VT-x, VT-d, TXT, AES-NI, Intel 64, Idle States, EIST, Thermal Monitoring Technologies, Intel Fast Memory Access, Intel Flex Memory Access, XD bit
The I3 would be enough but if you are looking at a quad you may as well go with 2500K over the 2500t as they are only about 10W diffrents really. and you could underclock it and down the volts. Or overclock it.
sure
This is an english site remember! lol
There are quads with low power usage, they are marked with an S.
2600S -65w 4c/8t
2500S -65w 4c/4t
2400S -65w 4c/4t
2500T -45w 4c/4t
