Intel E5300 Help
11 Nov 2009
Hi,
I was wondering if anyone would be able to help me with an issue i'm having with my new E5300.
CPUID appears to be showing the CPU running with x6 multiplier and only at 1196Mhz should this not be x12 or x13 and more 2596Mhz? Is this to do with my slow memory, my motherboard or some other factor? Would upgrading the memory or the mobo BIOS help at all? Or would i just be better off sticking my old Pentium D 3.0Ghz back in?
CPU-Z TXT Report
Binaries
CPU-Z version 1.52.2
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium
Codename Wolfdale
Specification Intel(R) Pentium(R) CPU E5300 @ 2.60GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
Core Speed 1196.7 MHz
Multiplier x FSB 6.0 x 199.5 MHz
Rated Bus speed 797.8 MHz
Stock frequency 2600 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 13.0x
Max VID 1.288 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008006h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
CPUID
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008006h
CPUID
Chipset
Northbridge Intel i945G rev. A2
Southbridge Intel 82801GB (ICH7/R) rev. A1
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual
Memory Frequency 265.9 MHz (3:4)
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12
Bank Cycle Time (tRC) 16
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (FFFFFFFFFFFFFFFF)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 165/Year 165
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
SPD registers
DIMM # 2
SMBus address 0x52
Memory type DDR2
Size 1024 MBytes
Part number
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
SPD registers
Monitoring
Mainboard Model ConRoe1333-D667 (0x00000424 - 0x2C92983C)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627EHF
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0x88
LPCIO Revision ID 0x63
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627EHF
Voltage 0 1.10 Volts [0x89] (CPU VCORE)
Voltage 1 1.10 Volts [0x89] (VIN0)
Voltage 2 3.31 Volts [0xCF] (AVCC)
Voltage 3 3.31 Volts [0xCF] (+3.3V)
Voltage 4 1.69 Volts [0xD3] (VIN1)
Voltage 5 1.74 Volts [0xD9] (VIN2)
Voltage 6 1.84 Volts [0xE6] (VIN3)
Voltage 7 1.62 Volts [0xCB] (VIN4)
Temperature 0 37°C (98°F) [0x25] (SYSTIN)
Temperature 1 38°C (99°F) [0x4B] (CPUTIN)
Temperature 2 53°C (126°F) [0x69] (AUXTIN)
Fan 1 2446 RPM [0x45] (CPUFANIN0)
Hardware registers
bank 0
bank 1
50 25 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
bank 2
50 2C 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
bank 3
50 03 00 03 03 00 01 03 03 01 01 FF FF FF FF FF FF
bank 4
50 1A 13 FF 00 00 00 00 FF 76 5E 1C 3A 09 FF FF FF
bank 5
50 CF 20 CB FF FE 87 D3 C0 DD CD 7B F5 FF 00 00 00
Hardware monitor Intel Pentium
Temperature 0 41°C (105°F) [0x3B] (Core #0)
Temperature 1 37°C (98°F) [0x3F] (Core #1)
Hardware monitor NVIDIA GeForce 9800 GT
Temperature 0 49°C (120°F) (GPU Core)
PCI Device
DMI
DMI BIOS
vendor American Megatrends Inc.
version P1.20
date 06/28/2007
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID 00020003-00040005-00060007-00080009
DMI Baseboard
vendor unknown
model ConRoe1333-D667
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) CPU E5300 @ 2.60GHz
clock speed 12694.0 MHz
FSB speed 200.0 MHz
multiplier 63.5x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM0
size 1024 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCIE1
type A5
populated yes
DMI Extension Slot
designation PCIE2
type A5
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 1024 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA NVAPI
API NVIDIA I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name NVIDIA GeForce 9800 GT
Revision A2
Codename G92
Technology 65 nm
Memory size 1024 MB
Memory type GDDR3
Memory bus width 256 bits
PCI device bus 3 (0x3), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1ACC)
Model ID 0x614 (0x913B)
Performance Level 3D Applications
Core clock 550.0 MHz
Shader clock 1375.0 MHz
Memory clock 800.0 MHz
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
dont worry its perfectly fine
when the processor isnt being used it slows down the processor to that speed
as soon as your cpu needs the extra mhz it ramps up to 2.5ghz or what ever the e5300 clock speed is
i have the e5200 :)
its called speedstep i think google it
