Hi
I just built a new system with an Intel E8400 dual core 3.00ghz plugged into a shiny Asus P5NT Deluxe. The first incarnation saw the processor running at over 70 degrees! So, suspecting a dodgy heatsink (using the stock Intel one that comes with the processor) I returned it to OC, who refunded immediately (thanks!). After some further research to check that there wasn't a generally acknowledged issue with these processors, I ordered a replacement. This one is now installed, again with the stock heatsink and runs pretty steadily at 56 or 57 degrees. I've seen it climb to 60. The motherboard seems steady at 44.
What I cannot tell is whether this is OK or not. I've read lots about the unreliability of the sensors/software and conflicting statements about what constitutes an OK temp range and what does not.
I'm running the Asus PC Probe software as well as Speedfan and Realtemp and they all report the same temperatures, so I guess it's likely that the figures are accurate enough.
So, do I have an issue here? If the CPU is running hotter than it should, will that impact performance? How do I check this? What should I do?
I'm not the expert that may seem to be in this forum regarding hardware (I'm a software person) so be gentle with me
Thanks in anticipation
I assume those temps are load, not idle?
I would have reinstalled XP but the persons PC that I was upgrading didn't want to go back.
