InTel extreme tuning utility / problems after un installing
28 Aug 2011
Hello
After i flashed my bios to the newest version , i was unable to open Intel extreme unility manage. So i uninstalled it. Now i receive The IOCBIOS service failed to start due to the following error: The system cannot find the path specified. in the event manage after rebooting.
I have tried reinstalling it and that FIXES the error ( at least it stops appearing in event manager) but i still can not open the program and receive other errors in the event manager : Intel Extreme Tuning Utility 2.1.408.41. The application tried to modify a protected Windows registry key \CLSID\{0000002F-0000-0000-C000-000000000046}\InprocServer32
ive tried and find any registry keys that might have been left behind but im still left with that error. I never had that error before , even after flashing the bios. Only after trying to uninstall the utility ( which stopped working after i flashed the bios) do i get that error.
my motherboard is a GA-PH67A-UD3-B3 and im using Windows 7 ultimate 64.
I used @BIOS utility to flash my bios , and made sure it had my correct motherboard before i used the program to flash my bios.
So.. just to reiterate ( since im probably not explaining this very well) The above error code ONLY appeared after i uninstalled Intel extreme tuning utility. Reason i uninstalled it is because it became unresponsive after i flashed my bios , no matter how many times i rebooted. The Error disapears if i re install the intel utility but then i still can NOT open the program and i receive the above mentioned warning in my event manager.
What can i do?? Do i have to do a clean install of windows or is there anything i can do to fix this ?? Or is this hardware related ??
P.S: i did NOT really use the Intel utility except for enabling Quick boot option on it. So i hadnt over clocked anything on it or something.
