intel from 32bit to 64 bit
9 Feb 2012
I have just made up a pc for internet use mainly and im running a NTEL BX80623I52500k Core i5-2500k Quad Core 3.3GHz (Sandy Bridge)
its showing as 32bit how do i change it to 64 bit
thanks in advance :)
What operating system are running?
You will need a 64bit operating system to use the instruction on the CPU which will require a re-install.
also how much memory you running
if you are running 4gb for above, you will only be able to use 3gb of it due to the limitations of 32bit. you will need 64bit to run more than 4gb :P
just thought I should let you know
