intel G640
28 Nov 2004
Hi i have a intel G640 cpu. will it be safe to overclock using BLK only.
had a 200 mhz overclok using BLK. any info would be great, thx in response. ;)
All depends if you think risking system stability issues due to messing with the BLK is worth a performance gain that you will only see in benchmarks and not be able to "feel"
A very small tweak of the base clock is safe. As above its not really going to get you any tangible benefits though. My living room system has a G620, and I've left the clock well alone for the said of stability.
i have tried it on my old G550 and got some instability issues.
i reverted it back to stock as the extra 150mhz was not worth it.
