Hi all,
I've not checked my CPU temperatures for a while, but I decided to do so the other day. I now find that my idle/loud temps are much higher than I expected them to be.
Gaming goes up to 90c.
Idle can hover around 50c.
Now, these might not be so bad, but I decided to do some testing. I tested whether or not applying pressure to the heatsink would change the temperatures at all, as I suspect the heatsink might not be attached as firmly as possibly.
I found that temperatures dropped 5-8c when I applied even a moderate pressure to the cooler.
Is this normal? Is there any way to more firmly secure the cooler, or am I stuck with a loose fitting cooler?
Thanks in advance
Thanks in advance
