The Ryzen 5 2600 will be with us very soon.
Ryzen is not an option as my CPU cooler won't fit.
They come with a cooler
8400 over any ryzen if gaming
Assume you have tested Ryzen 2000 series CPU's to come to that conclusion then?
I would think its most prudent to wait for the Ryzen 2000 Series to before making your choice, as its weeks not months away.
because amd, duhNope, but given the leaked benchmarks we have seen the i5 will still be faster.
And unless AMD have made huge strides with some of the smaller dev teams that use older engines ie pubg then this will still be the case. AMD come close in some and lose massively in others but hardly, if ever top the charts. The OP is going to be gaming so why settle for hit and miss performance?
Once you've got quite a few cores/threads I think it's fair to suggest faster cores may be better than more cores - but 4 threads is very low for quite a lot of games now. So I'd take the i5 for sure.If the i3 8350k were at a more realistic price say around the 120.00 mark that would be a better choice for the next few years has they overclock to 4.8/5.0Ghz and Ghz is still king of the hill when it is a choice between cores and speed. If you can put of the upgrade until next year the CPU and motherboard landscape will be a lot clearer and give you a better choice with AMD being the better option at this price range unless Intel can get their act together.
Although with the Ryzen 2 coming out in a few weeks, I would instead go for the Ryzen 2 2600 ($199), with 6 cores and 12 threads.
