intel i5 4670k best cooler
22 Jan 2014
Hello forum am looking to buy a cooler for the i5 4670k I will be overclocking as much as I can I don't want to be paying to much somewhere between £30-£50 I have the thermaltake speedo advance case so I should have plenty of room for a large cooler
Thanks for any advice
I would also throw in there that the Prolimatech Megahalems (revC) and a nice quiet fan (or two) is a rather effective cooler for the 3570K and it is super easy to install.
A couple of decent fans makes the price of that seem less attractive though, although I'd agree it's definitely brilliant for heat dissipation.
If you want to stay within the budget I'd throw the Shadow Rock 2 in there as well. Go for the Dark Rock 3 for more OC potential though (out of those two).
