Intel i7 12700KF Alder Lake build - Specification check
6 Sep 2021
Stoke-on-Trent
Hi Folks,
Any comments / advice on the following would be greatly appreciated.
Proposed Spec:
My basket at Overclockers UK:
Total: £1,085.19 (includes shipping: £12.30)​
Couple of Questions / Comments:
Case: I have chosen this case as it is one of only two Midi towers I have seen on OC that will allow me to install 4 x 3.5" HDD (3 in the cages and one in a 5 1/4" bay) this will also leave me one 5 1/4 inch bay for a CDR or another drive etc.
CPU Cooling: I intend to install the AIO cooler in the roof of the case as I need to use the bays at the front of the case. Will this cooler fit in this case in the roof with RAM clearance etc?
Any recommendations for an air cooling alternative that will fit the case
PSU:
The motherboard requires '2x2, 2x4, 12V Power Connectors and 2x12 Main Power Connector' presumably this PSU has these connections?
For the extra £10 is it worth me changing the PSU to the 850w version: RM SERIES RM850 850W '80 PLUS GOLD' MODULAR POWER SUPPLY (CP-9020196-UK)
Graphics Card:
Initially I intend to use my existing GeForce GTX 750 Ti while GPU prices are high. As this is a PCI Express 3.0 card am I correct in presuming this will work with the selected motherboard?
If not I will grab a CORE I7-12700K
Thank you in advance
Given the wilder rumours of high-end GPU power consumption, you may want to go with even more power.
I would go for the 850w and also the tenner extra for the K chip incase you have any UEFI compatibility issues as the GPU is quite old now and also piece of mind incase it fails given the prices and availability of new cards right now.
Looking at the case it should support a 280mm rad and has offsets but the freezer II is a chonky boy so I wouldn't like to say for sure.
