- 14 Feb 2009
I’m planning to build a gaming rig as my current one is rather outdated (4-5 years). I’ve never built a pc before but am pretty clued up on what’s involved and my own personal requirements.
My ultimate aim is to build a high-spec rig that can run Crysis on maxed out settings with good framerate @ 1920 x 1200 on my Dell 2407 Monitor. I figure if I can do that, the new rig should be relatively future proofed for gaming (if that is even possible in such a fastly evolving market lol!).
As well as a gamer I am also an aspiring 3d Artist, so the rig would double as a design tool for 3d / 2d based applications such as 3ds Max, Maya, Zbrush, and Photoshop, which require some serious rendering muscle.
I’ve done a fair amount of research into the various components available and have come up with the following shopping list:
Antec 900-2 Nine Hundred Two Ultimate Gaming Case - Black (No PSU) - £Already Purchased
Corsair TX 750W ATX2.2 SLI Compliant Power Supply - £103.49
Gigabyte EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard - £223.09
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) – OEM - £233.44
Akasa AK-967 Nero Direct Contact Heatpipe CPU Cooler (AM2/AM2+/939/LGA775/LGA1366) - £31.04
OCZ 6GB DDR3 PC3-15000 (3x2GB) Reaper Low-Voltage Triple Channel (OCZ3RPR1866C9LV6GK) - £229.99
GeForce GTX 295 1792MB GDDR3 TV-Out/Dual DVI (PCI-Express) - £436.99 (Cheapest ATM)
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) - £82.79
Asus DRW-22B1LT 22x DVD±RW SATA Dual Layer (Black/Silver) – Retail - £22.99
Arctic Silver 5 Thermal Compound (3.5g) - £6.89
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939) - £91.99
Total (inc VAT): £1462.69
I know that a rig of this spec does not come cheap, but I think the i7 processor and triple channel ddr3 memory will help future proof the system. I have however realised that the major costs are in the RAM and the GTX 295 card… I’m aware that the ATI Radeon 4870 X 2 card is cheaper and of a similar spec, but it appears that the GTX 295 performs better in most games (in online benchmark tests).
I suppose the question is: Is this overkill?
I have no problem spending the money as long as it is worthwhile, but I don’t want to spend unnecessarily. I could go with a cheaper SLI or Crossfire option but then I have no room for expansion. If I go with a single GTX 295 now, I could add a second in SLI at a later date.
Also would 750W be enough to power the rig with a single GTX 295?
Could 750W handle 2 of those cards later on down the line or would I need an 850 / 1000W PSU?
If some of you guys would be kind enough to share you’re thoughts on this with me, it would really help me out.
Cheers Guys!
Mike.
Cheers Guys!
Mike.
