- 24 Aug 2010
Looking at upgrading motherboard and cpu and ddr any help for a gaming pc? Thanks
Which are going to be just Coffee Lake with more cores.Intel is supposed to be launching it's 9000 series cpu's and Z390 motherboards in October
Sadly because of Ddr4 prices this is going to be an expensive upgrade as you can't use your ram. On a plus point though, being one of the best Ddr3 CPUs, the 4770k does have a good second hand value.Looking at upgrading motherboard and cpu and ddr any help for a gaming pc? Thanks
The 8 core cofeelake coming out in october would be a great upgrade.
Personally I would wait for that.
I'm in the same situation and I have the itch to upgrade. But when I run MSI afterburner I see my CPU isn't particularly taxed, and this is at stock settings - the highest I've seen is in AC: Origins which was 60%. This is with a 390X which is pretty much flat out 100% in every game at 1080p 60fps, and 'only' 8GB of DDR3 2133MHz (which goes up to about 6GB in use in GTA V and AC:O). What GPU and monitor do you have? I just can't see any point in it for gaming just yet, especially as I can overclock (again).
Edit - huh, it's more like 75% utilisation when stuff is actually happening in game. Guess I'll look back into overclocking it!
I have the same machine with a 1080 and all games are ok, no cpu bottleneck, I have it OCed to 4Ghz without changing voltages or anything just super simple OCLooking at upgrading motherboard and cpu and ddr any help for a gaming pc? Thanks
I think changing voltages you could do even 4.2ghz or more
