- 29 Jun 2019
Hello, I am not that good with OC.. I bought this I9 9900k already OC to 5 GHz with asetek 240mm AIO.
The temperatures in idle are:
The temperatures while gaming example: Monster Hunter World, Ultra settings with 2k monitor and g-sync enabled are reaching a max of 72 degrees.
Games like Insurgency or Ring of Elysium normally reach around 62-67 degrees. Can you please advise if that is a safe temperature for CPU? Not sure if that is relevant by GPU is running at max load at 70-71 degrees max.
I have Phanteks enthoo evolv x with 1x140mm at the back and 3x140 in the front plus of course AIO 240mm at top.
