Intel Mac hard drive query
29 Jun 2006
Cheshire
OK... this is what I was thinking as I rode back to work this afternoon...
I have a Mac mini and three hard drives:
i) internal 5400rpm 80Gb SATA
ii) external 7200rpm 80Gb USB2
iii) external 7200rpm 400Gb Firewire
I'm wondering if it's possible to install Mac OS X on the USB2 drive and have it work quite happily there as my main OS. Will my Intel Mac boot from a USB2 drive? If anything goes wrong will disk repair tools fix USB2 disks?
Then I would reformat the internal SATA drive and put on XP or Vista as neither of those will boot from external drives.
Then use the 400Gb external Firewire for data (partition a bit as FAT32 and the rest as HFS+).
Anyone know if this scenario is likely to work before I muck it all up this evening for nothing. Is it worth it? Will using an OS on a USB2 drive seem horrendously slow?
I think you'd be a lot better off doing it from a Firewire drive, but is it really worth all the effort?
I guess I'm just slightly disappointed with the hard drive performance in the mini. After a week of using it, it just seems to drag the OS down a bit. Things don't always seem as responsive as they should be.
Don't fancy cracking the case to fit a 7200rpm bigger drive in, as it will void the warranty and I've only had it a week! This is what you get when you're used to two RAID Raptors!
I think I will just leave it alone and put up with it for six months or so, before deciding to go Leopard with a Mac Pro or Vista with my own custom-built PC.
