Intel Management Engine Interface (MEI) Version 11.0.0.1156 WHQL
What is Intel Management Engine Interface, what does it do and why do we need it?
In general, the newer the board/chipset (Intel 7 or 8 series), the more you need the IME software. It's not a Gigabyte driver, it is from Intel and does many underlying things that are difficult to explain. All of the chipset's features may not work until IME is installed
What exactly is IMEI?
Most of the people still remain confused with the term Intel Management Engine Interface as they have little knowledge of the computer hardware. So, here is a short definition of IMEI. Basically, it is an interface that uses the Intel ME hardware features to enable an interaction between high- and low-level hardware systems in a system
Tasks performed by the Management Engine
The main component of Management Engine interface, ME performs a number of tasks in conditions when the system is running or in sleep mode. It also supports several tasks during the boot process. This sub-system is required for proper functioning and maximum efficiency of the PC. The interface checks whether the system is working properly or not while communicating with the operating system of PC.
Use of IMEI drivers
It is well known that the Intel Management Engine Interface enables effectual communication between the Intel Management Engine firmware and the host operating system. The Driver installs the hardware required for proper functioning of interface. Intel Management Engine interface driver support is different for different operating systems.
Wow there is new IMEI version 11?
Checked mine have 2 years old driver version 9.5.10.1658 installed from ASUS site 2 years ago.
Downloaded and will install new driver and see how it go.
I have version 10.0.30.1054 (driver date 23/09/2014) which was installed as part of the intel INF package (I presume) that I downloaded last week.
My PC ran fine with latest IMEI 11 driver after 4 days without issue. :)
Will install it on my Dell laptop Linx 10 tablet. :D
Hope the driver will be full compatible with Windows 10 when it install on 29 July.
