**INTEL MASTERS EXTREME MEMORY FROM PATRIOT COMING TO OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Patriot have worked with Intel to get the most bling memory for die hard Intel enthusiest, and I must admit they do look rather impressive. These are exclusively available from OcUK ONLY and stock arrives next week:-
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PVI38G160C9K) @ £89.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) @ £49.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Only £49.99 inc VAT.
ORDER NOW
Is there any variation between this and regular memory, other than the cooler design?
I'm awful at reading specifications..
