Intel My WiFi Technology
30 Dec 2003
Hello!
Could somebody with this installed pleae upload the corresponding start menu short cuts? I have accidentally deleted them and would like to recover them. It would appear that I've found the correct executable but it requires a specific switch and I do not know what that may be (and it is not documented as far as I can tell). Also the start in location and any other relevant information would be great.
Please! :)
Hello!
Please! :)
I don't have the software.
But, if you've just deleted the short cuts. Couldn't you just reinstall the software to get them back again ?
Or, find the program's location in the Program Files folder, right click on the .exe file and "send to" ... "Desktop (create short cut)"
Then you could drag the short cut back into the start menu list.
If the above doesn't work, I don't know what else to suggest.
Good luck :)
Good luck :)
I could reinstall the application but I'd like to avoid doing so for a number of reasons. I already know which executable to launch (and can create a shortcut to it) but it requires additional arguments/switches and therefore short of installing again I need somebody else who has this installed to tell me the exact shortcut path.
Thanks.
Morning,
All the shortcuts in the intel wireless folder:
Intel(R) My WiFi Technology
"C:\Program Files\Intel\WiFi\bin\PanUI.exe"
WiFi Advanced Statistics
"C:\Program Files\Common Files\Intel\WirelessCommon\imFrmwrk.exe" /sf Advanced Statistics
WiFi Event Viewer
"C:\Program Files\Common Files\Intel\WirelessCommon\imFrmwrk.exe" /sf Wireless Event Viewer
WiFi Manual Diagnostics
"C:\Program Files\Common Files\Intel\WirelessCommon\imFrmwrk.exe" /sf Wireless Diagnostics
Morning,
WiFi Event Viewer
Could you please upload the shortcuts for me? :) I'd like to see the 'Start in...' value, etc. I tried to contact you through Trust but it is not configured.
Thank you! :)
EDIT - Now sorted. Thanks for your help! :)
