The Plan is only applicable to Intel boxed processors – processors purchased in tray are not eligible and the plan will not be honored by Intel customer support for tray processors.
I think this is a disgraceful scheme by Intel. The K series are unlocked for one reason and one reason only. So that they can be overclocked. Any failure should be covered by the normal warranty and people should not have to buy "insurance" to cover their unlocked cpu's which cost more than a unlocked version does anyway.
So if you buy a car that can do 200mph you will drive it at this speed and when you crash you will blame the company?, Im sure there can be better example but you get the pointI think this is a disgraceful scheme by Intel. The K series are unlocked for one reason and one reason only. So that they can be overclocked. Any failure should be covered by the normal warranty and people should not have to buy "insurance" to cover their unlocked cpu's which cost more than a unlocked version does anyway.
That isn't seemingly what the point in the programme is, it's to allow people who end up with bum overclocks to swap their CPU for another one that might overclock better.
The Plan will cover the processor running out of specifications for the remainder of the standard 3 year warranty.
That's where things get fuzzy. In the T&C's for this plan it says at the bottom:-
That says to me that it covers the cpu for overclocking (extra voltage, BCLK, multiplier, mhz, etc) and seems to suggest that it's not covered under the normal 3 year warranty. If that's correct then that is a slippery slope they are going down.
