Permabanned
- 28 Nov 2003
- Shropshire
My Gigabyte Z97X GAMING 3 motherboard is currently using the BIOS Intel Rapid Storage stuff to run two identical SATA III D drives in RAID1. The OS and applications are on an SSD C Drive. My far more knowledgeable friends think BIOS RAID is flaky and I might have issues reading these drives if I have to change the motherboard for any reason. I do not expect RAID to be a substitute for good back up policies, but do expect a painless rebuild should a drive fail. I am asking if anyone has real world experience on the following please?
If a drive in the RAID1 pairing dies does this technology inform me immediately somehow? Or only when the OS (Windows 7 64 bit Pro) is rebooted?
Have you experienced any issues with adding a replacement RAID 1 SATA drive and it not rebuilding itself flawlessly?
Any issues with a dead or dying drive taking down the info on the good drive?
Any issues finding current motherboards that will just read the original RAID1 pairing as built by the original board, using Intel Rapid Storage BIOS RAID1?
If there are gotchas I'd bite the bullet and buy a "proper" Adaptec PCIe RAID card and run hardware RAID. I can do without nasty surprises
I have yet to experience a failure of a RAID drive, maybe I should try and test this setup somehow, any safe and simple ways of doing this?
Thanks for any replies!
I have yet to experience a failure of a RAID drive, maybe I should try and test this setup somehow, any safe and simple ways of doing this?Thanks for any replies!
