Ddr4 is x99 and above, so socket 2011-v3/h170/z170.
Unfortunately on the 1150 socket, ddr4 isn't compatible.
Edit:
If you still want a motherboard, with the above budget but with ddr3, you can go to the top of the budget with the Asus Maximus rog at around £150, or go for the msi krait, I believe its under £90.
Both on ocuk.
