Intel retail thermal paste, enough or not?
7 Oct 2008
Herefordshire
Hey guys/gals
Got most of my new pc stuff today, but I was just wonderin, is the thermal paste that is pre applied to the cpu cooler enough? It doesn't look like there is enough on there.
Thanks all.
Less is more with paste. If you have to use the stock then so be it, leave it be.
When you find yourself with better thermal interface use as thin a layer as possible.
^in which case that cooler isn't going to cut it anyway
Yeah, just making sure, I knew you shouldn't put a lot on as this deteriorates the cooling capability, but that really looked like there wasn't enough.
No Oc'ing for me yet, hopefully will get a Titen Fenrir and try my hand at overclocking, will buy some decent paste of course aswell as cpu grease cleaner.
Thanks for fast replies.
:D
It literally should JUST cover the base - the thinnest layer possible without having metal-on-metal contact (sounds like something Jaqui smith's husband rented)
It would be if there was no air between... I wonder if you could solder a heatsink to a CPU? :D
I guess that you could melt some silver and apply it to the heatsink, still melted, then apply that to the cpu heatspreader and clamp it down. The solder might be a bit too hot and kill the cpu though I guess, and you'd have to get it right first time!
Solder would do a very good job. Risks are damaging the chip (not major) and ending up with a heatsink/chip combination which you can't fit into the socket.
If you want perfection, the ideal would be a very clean and very flat copper surface on each, clamp together and leave at 80 degrees or so for quite a while. It'll weld itself together.
More sensible is to clean each surface and put 'liquid metal' inbetween, as it alloys to each surface.
