Hi there
Intel are giving us the ability to sell some of their fastest processors below actual trade prices, the catch is it is ONLY UPTO THREE PER CUSTOMER and the will withdraw the promotion support November 2nd.
The deals are below:
Intel i7-5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75930K) @ £425.99 inc VAT
Intel's latest Haswell-E 2011-v3 processors is the most powerful desktop gaming processor you can get, perfect for gamers, video encoders and professional audio. With a whopping 6 cores which means 12 threads with hyperthreading technology the power on tap is unlimited.
As always Overclockers UK have done some overclock testing and the results are very impressive with speeds of over 4.5GHz being achieved which for an 6/12 processor is very impressive. We are recommending custom water-cooling loops for people wanting to overclock beyond 4GHz to keep things cool and OcUK has the largest range of in stock DDR4 memory from Avexir, Crucial, Corsair and G.Skill.
Features:-
- 22nm Tri-Gate 3D Transistors
- 6 Cores, 12 threads
- 15MB of Intel Smart Cache
- Intel Turbo Boost Technology
- Conflict-free microprocessor
- Distribution of AI, physics and rendering across multiple threads delivers intense gaming exerience
- Faster video encode, image rendering, audio production, and real-time preview
- Overclocking-enabled for extra performance
- New Intel X99 chipset delivers enhanced I/O
- 4 Channel DDR4 upto 4266MHz support
Specification:-
- ONLY Compatible with X99 motherboards & DDR4 memory!
- 3.50GHz base frequency
- 3.70GHz Turbo frequency
- Fully unlocked
- 15MB Cache
- Intel Turbo Boost Technology 2.0
- Intel Hyper-Threading Technology
- Supports LGA 2011-v3 socket
- 40 PCI Express 3.0 Lanes
- Transistor count: 2.6 Billion
- Die Size: 17.6mm x 20.2mm
- TDP: 140W
- Thunderbolt 2 Capable
- BCLK Overclock support from Chipset
- Warranty: 3yr
Was [£469.99] Inc. VAT
Only £425.99 inc VAT.
ORDER NOW
Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K) @ £299.99 inc VAT
Intel's latest Haswell-E 2011-v3 processors is the most powerful desktop gaming processor you can get, perfect for gamers, video encoders and professional audio. With a whopping 6 cores which means 12 threads with hyperthreading technology the power on tap is unlimited. The 5820k is also Intel's lowest ever priced 6 core, 12 threaded CPU ever, making such power more affordable.
Features:-
Specification:-
- 3.30GHz base frequency
- 3.60GHz Turbo frequency
- Fully unlocked
- 15MB Cache
- 28 PCI Express 3.0 Lanes
- TDP: 140W
- Warranty: 3yr
Was [£311.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £249.95 inc VAT
Want to tune every aspect of your system for the ultimate in total system control. Then the new unlocked Intel Core processors which enable system tuning for the processor cores, memory, graphics, and power, were made for you. Whether you are a novice overclocker or a seasoned veteran, these processors will have you singing their praises in no time.
Looking for the perfect processor to build your gaming rig around? But you also want to edit your action videos and photos? But to do this you know you need serious performance. Not to worry - Intel is happy to announce our first 4GHz base frequency quad core processor. If it is performance you crave, then this is the processor you have been waiting for. But what if you feel the need to overclock your system to squeeze every last bit of performance out of it? Well, then this is still the perfect processor you. The lastest 4th gen Intel Core i5 and Intel Core i7 processors, paired with the latest Intel 9 Series H and Z chipsets, will get you the results you want. Add in features like built in visuals and Intel Quick Sync Video, which allows the conversion of media from one device to another and prepares your media from one device to another and prepares your media to share online at incredible speeds, and these are processors that meet every need you have.
The Intel Core processor family delivers a great PC experience. Whether you are looking for improved performance, greater adaptability, or differentiated visual features, Intel has the processor to fit your needs. Whether you use your PC for creativity, playing games, or everyday task such as homeworkd and email, these new processors make it easier to design, render, edit, play, and share.
Intel Core and for Intel Core i7 processors, Intel Hype-Threading Technology allows each processor core to work on two task at the same time, improving multitasking, speeding up the workflow, and accomplishing more in less time.
With 4th gen Intel Core processors, you can boot your PC, load applications, and resume from sleep nearly instantaneously thanks to Intel's responsiveness technologies such as Intel Smart Response Technology and Intel Rapid Start Technology.
The 4th gen Intel Core processor family offers hardware-level security that helps protect your devices, your data, and your online transactions.
The 4th gen Intel Core processor family automatically connects to wireless hotspots. Your email, social media, and apps are always updated thanks to Intel Smart Connect Technology. Finally, wirelessly stream your HD / 3D video and games to your TV or projector for presentations and entertainment using Intel Wireless Display Technology.
Features:-
- Improved thermal interface material (TIM)
- Updated packaging materials
- Supported by new Intel 9 series chipset
- Re-engineered for Enhanced Performance & Overclocking
Specification:-
- Lithography Process: 22 nm
- Cores: 4
- Threads: 8
- Frequency: 4.00 GHz (Turbo Mode 4.40GHz)
- Integrated HD 4600 Graphics
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 1600/1866/2133/2400/2666+ MHz
- Socket: LGA1150
- Memory compatibility: All DDR3 1333MHz and above is compatible
- PSU compatibility: Check out our range of Haswell compatible PSU's - http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=2597
- 3yr Warranty
Was [£289.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail @ £169.99 inc VAT
Features:-
Specification:-
- Cores: 4
- Threads: 4
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- Cache: 6MB shared L3
- Socket: LGA1150
- 3yr Warranty
Was [£199.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Intel Core i5-4590 3.30GHz (Haswell) Socket LGA1150 Processor - Retail @ £149.99 inc VAT
Intel's 4th gen processor codename: Haswell offers superior performance over the previous generation Ivybridge by up to 10% clock for clock. This astounding performance boost results in performance improvements in multi-tasking, encoding, gaming and multithreaded applications. Intel's 4th generation processor has improved PCI-Lane 3.0 bandwidth which helps further boost performance of latest generation 3 graphics cards for the ultimate gaming experience.
For overclocking enthusiasts, Intel's 4th gen CPU has improved memory overclocking support, with up to and beyond 3000MHz possible with the very best memory kits. Memory bandwidth is critically important to Haswell compared to previous generations. High frequency memory performance significantly improves encoding, gaming and benchmarking tasks.
The biggest leap in Intel's Haswell processor is the onboard graphics which is now up to 2.6x faster than previous HD4600 found in the Ivybridge CPU. What this means is these latest processors can actually play the latest games in HD with low/medium settings applied. Of course if you want to experience True HD gaming at maximum details then a dedicated graphics card is still a must.
There are two words in your vocabulary that should never meet—Game and Over. You love playing, and you love winning, so you demand unmatched performance, the ability to customize your rig, and features that put you in control of the action. With Intel® technology, you step into a heart-pounding experience. Pick up your weapon, challenge your friends, and experience gaming at its best—because the only thing more amazing than Intel® technology is what you’ll do with it.
As a creative force and a professional, you must continually balance your vision with the deadlines of the real world. Intel® technology helps you keep up with your creativity with unmatched and customizable performance, and features that give you full control to optimize your workflow and maximize your productivity. So keep imagining, keep creating, and take your inspiration to the limit—because the only thing more amazing than Intel® technology is what you’ll do with it.
Features:-
- Upto 10% performance increase over Ivybridge on CPU performance
- Upto 2.6x performance increase on 3D Graphics (onboard GPU) with DX11.1 Support & OCL1.2
- Better OC Flexibility with memory timings and speeds
- 4k and Collage Display support
- Intel Password Guard for SBA and improved protection against data theft
Specification:-
- Cores: 4
- Threads: 4
- Frequency: 3.30GHz (Turbo Mode 3.70GHz)
- Cache: 6 MB shared L3
- Socket: LGA1150
- 3yr Warranty
Was [£155.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Intel Core i3-4170 3.70GHz (Haswell) Socket LGA1150 Processor - Retail @ £85.99 inc VAT
As the first level of Intel’s latest processor family, the 4th generation Intel® Core™ i3 processor provides you with responsive performance to multitask with ease, vibrant visuals, amazing battery life,41 and built-in security features to help keep your data safer.8 Effortlessly move between applications with smart multitasking delivered by Intel® Hyper-Threading Technology.2 Experience your movies, photos, and games with stunning HD, 3D, and graphics performance built into the processor—no extra hardware required.3 Get a difference in the performance and experiences that you can see and feel—all while enjoying the peace of mind from enhanced security, and the flexibility of amazing battery life.41 Experience the power within your PC, and (re)discover what’s possible with a new computer.
Features:-
Specification:-
- Cores: 2
- Threads: 4
- Frequency: 3.70GHz
- Integrated HD 4400 Graphics
- Cache: 3MB shared L3
- Socket: LGA1150
- 3yr Warranty
Was [£104.99] Inc. VAT
Only £85.99 inc VAT.
ORDER NOW
The price on the 5930k is pretty incredible to be honest, a near good £50 saving.
Features:-
Specification:-
- Fully unlocked
- 15MB Cache
- TDP: 140W
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- Fully unlocked
- 15MB Cache
- TDP: 140W
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- Cores: 4
- Threads: 8
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
Features:-
Specification:-
- Cores: 4
- Threads: 4
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
Features:-
Specification:-
- Cores: 4
- Threads: 4
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
Features:-
Specification:-
- Cores: 2
- Threads: 4
- Socket: LGA1150
- 3yr Warranty
ORDER NOW
