Intel Stock Coolers C2D
24 Jan 2007
Hi guys, just wondering whether the stock cooler you get with the C2D is sufficient to do the job and also are they reasonably quiet or would i be better of going for a Zalman CNPS9500-LED Socket 775?
Looking to build a cheap new C2D rig with 6750 2.66 or Quad Q6600...just not sure between the two which is worth the investment.
Not looking to overclock that much, more use for everyday tasks along with video/photo editing/multi-tasking. Not for games.
Regards
Dr K
Thanks for that.
I was going for a cheap mobo ie Asrock motherboard ConRoe1333-GLAN LGA775 and Corsair Value Select 2Gb DDR2 PC5300 memory kit (2 x 1GB) RAm. What you think?
taa for that but just realsid that mobo doesnt support Quad, may go for ASUS P5B 775 Motherboard unless u can advise another for aound £60 or less.
