Intel TAT not working
30 Aug 2006
Ive installed TAT but when I click on the icon & accept the licence agreement something flicks up for a second and then dissapears. Ive tried running it as adminatrator but it made no difference. Im running Home Premium 64 bit if that helps.
:( Vista truely is useless right now. Aside from playing minesweeper with better graphics I am not benefiting from using it whatsoever, tis a shame I am to lazy to go back to XP.
no ITAT doesn't work on vistax64 i found this myself so i just use orthos to prime and it's fine, i can't see your major issue with not using ITAT there are other ways of testing stability ;)
Orthos and Core Temp are perfect, core temp even reads the offset of 15oc for E4300s correctly :)
