Man of Honour
- 17 Feb 2003
- Chelmsford
Hi,
I'm hoping there's a good answer to this problem.. I bought a small little mini-PC just for work use, it's quite and requires little power so ideal for working all day on. However, my gaming monitor only runs 4k at 75Hz, where as it seems the Intel UHD is inly running at 60Hz.. As a result, the resolution s defaulting to 2k whic is a bit annoying.
I'm wondering if there is anyway I can get this to run at at 75Hz to meet the minotr requirements. The screen shot below says maximum of 120. The mini PC only has HDMI, and I'm using the high speed versions which I have tested on my main PC.
Thanks
Thanks
