Intel vs Ryzen CPU height and air coolers
15 Feb 2009
Hi all,
Bit of a weird question, I have the Lian Li OL11 Dynamic XL case, currently with a 7700k and Noctua U14s cooling it.
As it stands the cooler is pretty much touching the side glass ie. zero room for manoeuvre.
If I move to Ryzen in the next 6 months or so, is this going to change whether i can still use the U14s to cool it? Basically i'm asking if the physical height of a mounted AMD CPU is the same as Intel!
If Ryzen is indeed a taller cpu, then i may have to look at something like the Scythe Fuma 2 instead.
Many thanks!
When you say pretty much touching the side glass, how close do you mean?
I can't imagine there's more than 2-3mm height difference at most, if there's any at all.
