Intel xenon e3-1230v, gtx 780 low fps while recording
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
Hello, my friend is having trouble with his new riq, as the fps only while recording drop drasticly to 20-25fps. One of the examples is minecraft, from 250-400fps to 20-23fps. But the problem appears also on games like mafia...
Spec:
Intel xenon e3-1230v3
Cooler SilentiumPC Fera 2 HE1224
MSI-B85 G43SC
Asus PCI-N10
Crucial Ballistix 16GB (2x8GB)
SSD Plextor 128GB
Western Digital Green 2.0TB
Gigabyte gtx 780
Corsair RM 650w
System: Windows 7 64x Ultimate
The problem is I can't physically go on to the PC, the things I could have checked by teamviewer. I have checked and the pc seems to be fine, as there are no problems when not recording. :confused:
Edit
Actions taken
- Benchmarking done by programs such as: Valley Benchmark, 3d firestrike, Intel Burn in Test
- Reinstall of the whole system
- Reinstall of different drivers
- I played around with the 3d settings but that didn't help either.
Edit2
Where are the recordings being saved? What software is being used to record and at what settings?
I tried both, SSD and WD = Same outcome
Program are: Fraps, OBS, Action!
These programs are installed on the WD green, so are the games
^ If it's being saved to the WD Green that's probably the bottleneck due to it spinning much slower than your usual drive.
Edit
He installed the drivers by 'DriverEasy'
Edit2
Now after doing a system restore he has around 40-60fps in Mafia 2 with everything maxed out.
My go to recording / streaming is usually OBS or DXtory if that doesn't work which is rare these days.
Is he using direct game/surface capture or screen capture ?
Screen capture will run like turd FYI.
