- 1 Jun 2010
- Bedford
Hi guys I am trying to test my [email protected] for stability. The Vcore is currently 1.36875V. I first ran Intel burn 'standard' test with 5 iterations and it failed on 2nd iteration as Vcore was 1.36250V. So I upped it by one notch to the current value of 1.36875V.
I ran the same test again and after 5 iterations it passed the test. Not satisfied I just increased the iterations to 10 and ran the same test again. This time on the 4th iteration it failed
I then decided to test my cpu with 'maximum' test and lo it passed after 22s.Lol. I was like what the heck is happening. Also the temperature readings on CoreTemp were fluctuating sometimes from 65C to 52C and viceversa. So guys what could be the problem; is it could be some sort of bug?
.I then decided to test my cpu with 'maximum' test and lo it passed after 22s.Lol. I was like what the heck is happening. Also the temperature readings on CoreTemp were fluctuating sometimes from 65C to 52C and viceversa. So guys what could be the problem; is it could be some sort of bug?
