- 17 Oct 2002
- West Midlands
Apologies for the random tittle but ive got a quick query for people familiar with Vlans.
I have a site with a primary router being a Cisco 3640, it has one serial interface and two fast ethernet interfaces all of which are on separate networks.
Hanging of the two fast ethernet interfaces i have a 24 port L2 Managed switch that is Vlan capable.
Into the other ports on the switch i have multiple firewalls each with unique addresses within the range of the network that of the fast ethernet interface on the router.
Now my plan was to configure two vlans on the switch the use 802.1q encapsulation on the router to route between the vlans, unfortunately i have since found out that the IOS version doesnt support said feature as its using only the basic IP feature set and i am unable to upgrade it due to hardware constraints.
My question being would it be acceptable to simply plug all the devices into the switch as members of the native Vlan and let the laws of physics decide the outcome, i have tried this and it is successful, trace routes show traffic passing through the router between the two networks connected i imagine this is the case as each firewall has the router as its default gateway, any suggestions or potential downfall's welcome.
The diagram below is what i would like to achieve, Please note that IP address's are fictitious as well as the router/switch hardware but it's close enough
Current Setup
Proposed Setup
Current Setup
	Proposed Setup
