Interactive logon text background
4 Jan 2004
Nottingham
This may be a bit too specific but worth a shot.
We're trialling W10 enterprise and have upgraded a couple of laptops and a surface from W8.1 enterprise to W10. One of the laptops was a fresh install while the other and the surface were in-place upgrades.
We use the interactive logon text as an AUP before you login which seems to look different on each of the devices. When you're at the W10 lock screen and click/swipe to get to the login screen, the laptop with a clean install just switches to a plain blue background with white text on it and an OK button. Once you click OK this disappears and the normal W10 login screen is visible. On the other laptop the blue screen and white text doesn't show, instead the white text is just overlaid on the same background colour/image as the login screen with the users name/profile image above it.
The surface originally overlaid the text in this same way but has since started showing the blue background and white text and I have no idea why it has changed.
This is a long shot but does anyone know how to get the interactive logon text to simply be overlaid on the login screen rather than being shown on a plain blue background?
