Interactive Whiteboard
15 Apr 2012
UK
Been asked to look into this for a client. They are a school and at present are using a TV hooked up to a pc which is not ideal.
Anyone use one of these? Ideally they want the full package where the pupils can write on the board. 65" screen or larger, 1080p mimimum.
You can now actually do this with TV's where you "write" on the TV with a pen. Been able to do this for ages.
Depends on your budget.
If you want a whiteboard google SMART - smartboard
I use one at my company I work for, I believe it's from a manufacturer called SMART iQ, but don't quote me on that. They are surprisingly good and also can store a memory of 'flips' for displaying in an order you choose similar to a conventional flip-chart.
As stated, a quick google search will help you find something, not sure it's an OCUK stocked item, but you never know, might be worth a ring they may even know somewhere to get one.
Smart boards are quite expensive (bulbs, filters etc to change) also Smart software can be expensive too.
i am looking at interactive panels (tvs) which in the long run will be more cost effective and some have Android OS built in.
