Intercooler spray kits?
1 Jan 2010
Cirencester, nr Swindon
Got a new FMIC coming to replace my crappy factory hidden SMIC so i can safely up the boost and keeps temps reasonable.
Would i see any gains from using a IC spray kit on 300bhp @ 20psi?
Are you getting a kit so it fires automatically, or using it on manual? The former: maybe a little, if you do a lot of boosting repeatedly. The latter: no, because if you're boosting hard you'll be too busy to press the button. In normal day to day driving, no.
M
