- 30 Apr 2009
'Ey up kiddos,
Rig =
C2Q6600@Stock
8Gb OCZGold PC8500@1066, 2.1V [as spec]
XFX 4850 XXX @ stock, with TRad2+Noctua NF-P12 120mm fan [was an NF-S12 but swapped as the P is better suited to this sort of load as I understand it]
Having an interesting problem with the card. I'll play something like FEAR2 @ 60FPS with everything maxxed for about a half hour, and the machine will die. Which points me to the GPU.
But when it comes back up, it will sometimes give me a BEEEEEEP BEEP BEEP BEEP which is AM Bios code for "your HighMem is screwed".
Which is what led me to upping the voltage to the recommended levels as suggested by OCZ, rathe than letting the mobo set it automagically.
But I still get this problem - although it is better now that I have removed the inline resistor from the fan on the GPU to have it running it full whack.
Idles about 40, under load - as it has been for the last half hour running FurMark stress test, my temps are
GPU DISPIO = 60-60.5 stable
GPU MEMIO = 66.5-67.5 stable
GPU SHADERCORE = 62 stable
CPU is floating about 50-55 but given the case temps are up a bit that's no shock.
That's running at 1280x1024 with 8X MSAA with Furmark set to the 'kill my GPU' setting basically. It's fair hammering it, case temp is up to 45 degrees, highest I have seen it for ages. Note that I normally have my fans on nice and low as I, as Depeche Mode would put it, Enjoy The Silence.
I'm going to stick it on at 1080p windowed in a bit and keep logging, but do those temperatures look OK? As it's a third party cooler, is there something I am likely to have left off which is overheating? VRMs or something?
I remembered my old school computing education that anything out of lowmem is high mem - so the MEMORY FAIL bios beeps are probably referring to the VRAM yes?
Suggestions welcome - I don't mind pulling the card out and pulling off the HSF to show off the VRAMsinks if anyone wants to see that.
I have shifted the fan over to the left a bit to cool the RAMsinks a bit better - as I say, it's not an NF-S12 fan any more, it's a P12, excuse that, these piccies are from when I first joined and someone was after info on the TRad - I was just installing it so took a few snaps.
the only 'dodgy' RAMsink I have - not enough clearance for a full one. Possible cause of the problem?
Thanks in advance...
Rig =
C2Q6600@Stock
