bUt BnQ oNlY sElL tHaT sIzENo, that's the wrong size.
There is only so much you can take off each edge, and that's too much.
You need 726. That allows a few mm each side for space.
You can always fill a gap with a sliver of wood, but if you take too much off a door it is ruined. But 726 should be a perfect fit.
The doors options are: So which size would you recommend for a 73cm wide door frame? Seems 762mm is the only option and it will need to be sanded/cut down.
All doors between 700mm and 800mm at Homebase are 762mm wide.
And it still wouldn't fit anyway.Otherwise it's available in 762mm but can be trimmed by 32mm (16mm each side), which gets you to bang on 730mm (but I wouldn't want to trim that much if it can be avoided)
Depends how accurate his measurements wereAnd it still wouldn't fit anyway.
It's simple. Buy the door you have to trim the least. This is not due to hassle, it's due to structural integrity of the door. Even my 40KG fire doors only allowed a certain amount trimmed off sides and top/bottom. You can go over it sure. Loooaaads do. But you only want to go over by the smallest amount possible.
I learned the hard way that if you DIY and have the tools and patience, you can usually do a better job than even pros. Pros are pro because they bash out the job to a good enough standard, quickly, with confidence. It is their living after all.
Features and benefits
- Solid core for a heavyweight feel, as well as improved performance and durability vs hollowcore doors
- Supplied Primed with a white base coat, ready for finishing in your choice of colour
- Woodgrain textured effect finish
- Made from responsibly sourced, Forest Friendly timber
- The solid core can reduce sound from neighbouring rooms and can offer added insulating benefits due to there being less air pockets within the door. An ideal choice for today’s home working environment.
The carpenter who installed the laminate flooring & trimmed two 1000 wide fire doors in our new study charged us £150/day + materials (at cost: £28 for 2 thresholds & grey silicon sealant).
He took 2 days (9-5 first day, 9-3 second.day).
He usually does bespoke kitchens & interiors, but had a cancellation the same week we wanted to finish our room. Really impressed with his work and I didn't begrudge paying the full day rate, when he finished earlier than expected.
He vacuumed & swept up his mess (even asked if he could mop!) and took waste off-cuts with him as he already had a booking at the tip.
We've already booked him to come back and install our kitchen in June (estimated 8-10 days, same rate) and redo the rest of the ground floor laminate in July (we installed it, badly, when we moved in).
Finding a decent tradie who charges fairly and takes pride in their work is getting harder & harder, it seems.
I have to disagree with that m8Unless you’re getting hardwood doors, you should always get them fully finished so once they are hung. That’s it done!![]()
I swapped all the doors in our house and I can absolutely see why trades charge what they charge.
It’s a pig of a job which you need good tools for. If you are hanging into existing hinge points, it’s very fiddly and you have to be spot on. I’m a pretty competent DIYer and the most I managed in a day was 3 and that was not a 9-5 day.
We were putting in oak (not solid) and they weighed a ton, the wider doors on the ground floor I couldn’t safely lift on my own.
You can buy door lifter air bags you pump up with your foot for about £10. Most other things a DIYer would have; pencil, ruler, screwdriver etc.
