Interlevered or fast path
You will see a 8-32ms difference in gaming pings. If you haven't asked then you could reduce your Max delay to 8ms instead of whatever default BT put it at.
If your line is stable right now then it's worth trying it. I'm assuming you're on ADSL broadband with BT right?
Yeah ADSL2+ with BT and line is stable. Emailed a BT MOD through the BT broadband forums, heard you get better results that way than going through the pain that is calling India. Seeing as I should get better latency online in games then I think it's worth trying, cheers for the replys.
