Hello all. I've recently built a new system and have been getting almost constant BSOD's (MEMORY_MANAGEMENT_ERROR and 'ntfs.sys' driver crashes) in windows 10.
System specs are:
Processor
I7 6700K Skylake
Motherboard
MSI Z170A M7 GAMING
RAM
Corsair Vengeance® LPX 8GB (2x4GB) DDR4 DRAM 3200MHz C16 Memory Kit
So far I've tried:
- Reseating the ram
- Formatting SSD & resinstalling windows 10 (3 times!)
- Checking all board connections, wiring etc
- Checking capacitors for damage
- I ran 'CrystalInfo' SSD checker and the drive report stated 'Good/healthy'.
I then ran 'memtest 86' for five hours (with and without the 'XMP' profile enabled) and got 9 errors (see image below)
I contacted Overclockers.co.uk (where I purchased the RAM modules) and requested an RMA. I've now sent the modules back. However, I'm confused as to these RAM issues as the board specifications state that the ram and the OC/XMP profile (3200mhz) are supported. I don't want to get the same ram type back and encounter stability/compatibility problems.
I'd like to ask the good folks of OCUK forum: could it just be faulty RAM module(s)? or is it an issue to do with RAM timings or some other setting I've overlooked when matching the RAM to the Motherboard?
Also: I've read worrying posts on forums about 'bent processor pins' and the like, and as I've never had this issue in years of building my own systems, I'm not sure what the 'standard' RMA policy is, if the board or processor was damaged and needed to be returned. Together the board and processor set me back £460, so I'm dreading the possibility of having to pay for replacements..
Thanks for taking the time to read/respond.
System specs are:
Processor
I7 6700K Skylake
Motherboard
MSI Z170A M7 GAMING
RAM
So far I've tried:
- Reseating the ram
