- 9 Jun 2006
Hi all,
I've been having problems with my ADSL service with Virgin Media ever since I started a contract about a month ago.
The problem is, my connection drops to an extremely slow speed every few hours (DL of 0.5Mbps from 3.5Mbps). The router logs show there is a high number of packet errors and that the connection eventually drops entirely before it reconnects. It can take a while before the router works out something is wrong and reconnects. Reconnecting either by restarting the router or letting the router do its thing results in me getting the normal speed again.
I have been ringing VM on a regular basis to get the problem resolved but we seem to be going in circles now. I go through the all the tests/checks they want me to, then eventually it gets raised up as a case to 2nd line support. These guys then do a quick line test, and as the problem is intermittent, they don't see the problem and close the case down. This has happened twice already and I have spent countless hours ringing and doing their poxy tests only to go round in a circle again.
It seems yesterday evening they closed my case down again and only today was I told they had assumed my intermittent problem is attributed to P2P software use, and completely disregarded all the information I have given them that clearly shows that the problem is not my end.
So I'm stuck right now as to what to do. Can I get out of the contract by claiming they are not providing a reasonable service? Can I complain to OFCOM (or someone else) to get something done?
Much appreciated if someone could give me some advice as to where to go next
