Intermittent Display issues
6 Dec 2015
Hi all
I have put this under graphics, although I am not sure.
I keep getting problems from when the PC is on standby and I cannot get the display to come on, I have to cold start and then still no display, it can take a number of cold starts for the screen to display.
When it does again, the problem doesn't occur afterwards for a while.
I am running an older MSI Optix Mag with a 5060 ti.
I also get 4 beeps sometimes when it cold boots, which I believe can be memory, but why is it intermittent.
Can anyone offer any ideas.
Many Thanks
What are the rest of your system specs?
I encountered something similar with my 5080 on my last platform (B550 motherboard, 5800X3D) which (IIRC) I seemed to resolve by reseating the card and plugging the power cable in again (it was definitely seated correctly the first time as I was paranoid after reading all the reports of melted cables).
In my case it would output display successfully every time after a power cycle, however.
Which drivers do you have installed, the latest? Has it always behaved this way, or did it start recently?
